Old 07-08-2015, 08:36 AM
Cobra #3170 Cobra #3170 is offline
Default Rotors and SAI
Originally Posted by Morris View Post
Bruce
Good luck, your post are great to read.....and I wish I could help you more....but all my experience is RR......
BTW....what size are your rotors .....and what about the inclination angle of the spindle
,...just thinking out loud....
Keep the thoughts coming.....
Thanks Morris,
Rotors are 13" really tight package because I have a .5" scrub radius the upright is inside the wheel, the caliper clears the wheels spokes by less than .1" and the tie rod end is right on the brake disk for Ackerman. I wanted to use a cartridge bearing design but could not package it. with everything else.
SAI is 13.5 Degrees. These little master cylinders are not helping either (AP with 1" stroke). I did find that the pistons are not perfectly centered on the disk so I will shim to correct but doubt that will help knock back. Should have gone Brembo in the beginning and would not be fighting it now.
Tried to save some $, now will probably have to pay again to fix it.
