Looking good Glen.
Tim,
The fuel tank is custom and mounts below that "outrig" at the rear.
The roll bar attaches on that ledge behind the driver and into the boot as usual. There are steel shear plates you attach behind each point, and you drill the holes once everything is lined up. The mount points and rollbar are separate, so can be dismantle if required.
They do it this way now I think mainly because you can also get the optional passengers side roll bars, and it will make a LHD chassis simpler too. And it is easier to line everything up this way.
Cheers!
Guy
Cobra Progress guye-cobra.blogspot.com
