Old 04-27-2002, 07:21 PM
boxhead's Avatar
boxhead boxhead is offline
Default it all depends
You will need to balance the half shafts if they are a tube style shaft , ie same as tailsaft.
If your half shafts are a solid rod with cv joints ,as in most front wheel drive cars , then you will not need to balance.
I have seen jaguar half shaft that was out of balance because a weight had fallen off.
Cruising in 5th
