The fans have to have both positive and negative. Find the positive and check with a multimeter or a 12v test light at the fan. If voltage there - the fan is bad . Trace the positive back to either a fuse or a temp switch. Check for voltage there. If a temp switch - it should be adjustable, see if adjusting turns on the fan.
