Old 07-20-2015, 12:15 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I know you are not going to want to do this for fear of discoloration but try putting a little heat from a map torch. Get your wheel off the ground then put a little heat all around the spinner for maybe two miinutes and hit it in the correct direction. If it blues a little the Harley shops sells a powder that works great to get it back to it's original color or just sand it with some 2000 grit sand paper and polish it back to normal.
"Let's roll"
"Be part of Something Good
