Thanks, that helps a lot. On mine there is a large square panel on the right wall of the trunk. The electric fuel pump is mounted there and there is plenty of room to mount a high catch can. Also there is room in the opening for the fuel lines for a breather line to go through too.
Removing the top plug on the diff, and replacing it with the 1/2" elbow will be tricky part.
