Old 07-22-2015, 08:35 PM
leroy17's Avatar
leroy17 leroy17 is offline
Originally Posted by cobrarkc View Post
I am no expert on this however a quick look at the willwood site shows that this caliper (above link) has a 1.7in2 pad area, when the one that you have has a .9in2 pad area.
Nearly double the area and I also note that the above has a piston (single at 1.19in) and the smaller appears not (just reading the wilwood material, I have not actually seen it).
This could be a solution, sell the wilwoods to someone in karting, get the above wilwoods...... wheel not re-invented, problem solved.
Wilwood High-Performance Disc Brakes - Search: mechanical brake
