Old 07-25-2015, 05:15 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
If the engine is running well with no to much fuel then it is most likely OK. As stated before, vacuum secondaries on this engine would be preferable to mechanical ones or a double pumper carb. Also if the carbs on the engine are matched to the cam and other specs you should be OK. Just sticking two carburetors on an engine doesn't necessarily add power. In fact it can decrease the power.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
