Do you mean the gears in the motor unit or the wheel boxes at the wiper.If the drive wire is skipping by the drive on the wheel box ...that can be adjusted by bending the bottom up toward the wheel a small amount or the side cover with the two screws can be bent closer to the wire or both...the wheel may be worn by now so check that first
steve
