Old 07-26-2015, 04:41 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Double Venom View Post
DanEC,
IS that DUAL set up by, "PRICE MOTOR SPORTS?" Ours was by far the most professionally built "After market" product I have ever seen. Bar non...well maybe Wilwood products, Flaming River and maybe a few others. BUT still the best..
DV
No, they were initially set up by Keith Craft but I've had both apart and done a lot of fiddling with them since - and I have to admit they are base line 1850 carbs. I have them on a 63 - 427 low riser intake. But they do run pretty nice and the intake makes excellent torque. After Holley and Carter introduced their bigger carbs in the mid-60s the need for and advantages of the multiple carb set-ups more or less faded. I know - and agree - that they won't out-perform a good single barrel carb on a good manifold. But they do look sexy and I don't mind spending a little more time setting idle mixture and speed.
A good question to ask yourself to see if dual carbs are right for you is - do you mind running points and setting dwell? If points drive you nuts and seem like unnecessary maintenance and you will only settle for an electronic ignition - get a single carb set-up or fuel injection.
ERA 782 Running
