Originally Posted by colubra
Did speak to previous owner and while he did not recall the exact cfm(might be 600), he said the mechanical secondaries had been disconnected. What issues and concerns would this bring about. Thanks to all as I am learning a lot. Will be able to get pics this weekend.
You can get the carb specifications from Holley if you have the carb number(s). The list number for most performance and factory 2 and 4 barrel carburetors will be found stamped into the upper right hand corner of the airhorn or sometimes called the choke tower. On the 4150 HP models that do not have a choke tower the list number will be stamped into the mainbody behind the throttle linkage. This number is used to identify the carburetor and also used when needing service parts or renew kits. Source:
https://www.holley.com/support/faq/
Once you have that number(s), go to
http://documents.holley.com/techlibr...al_listing.pdf and you can get the specifications and service part numbers.
