Originally Posted by PeteF
Also make sure the system is holding pressure. A pin hole leak in the new tank, or any other leak in the system could be preventing pressure to hold. The top radiator hose should be hard to squeeze when the engine is fully warmed up. You can also rent a pressure test kit at most auto stores, to pump up the pressure and see if it holds over time. Good luck.
Pete:
I have a cooling system pressure tester and the system is holding the pressure fine.
