Old 07-29-2015, 08:54 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I have built several Cobras and a couple Daytona Coupes and I used a 3/4" mastercylinder for each one. I also like the internal release bearing that McLeod sells. I have also used one of Tiltons that worked well. In my new Daytona Coupe I am building with a Coyote Engine and TKO 6060 6 speed trans I am using an original Ford release bearing and a 3/4" master cylinder.
IMO you may need to flush the brake fluid and re bleed your clutch and brake system. I probably needs it anyway.
Clois Harlan
"Let's roll"
"Be part of Something Good
