Originally Posted by DanEC
If you have high pedal pressure and excessive travel then you have problems - because to lessen the pressure you will need to go to a smaller diameter master cylinder that will lengthen the travel further. Or to lessen the travel you can go to a larger master cylinder which will increse the pedal pressure even more. That's the trade offs in a master cylinder/slave cylinder system. Maybe it's the pedal set up. Can you identify the pedal set up or take a picture and some dimensons of the arm dimensions and dimensions to the rod attachment points?
I agree!
Tommy
Previously owned EM Cobra
