Old 08-03-2015, 08:44 PM
razerwire razerwire is offline
Cobra Make, Engine: csx4163 full comp alu. body
Have pedal stop like cobrakiwi on csx car and works well to stop from putting pressure on throttle bodys. I had a problem with key switch being loose just slightly and I let it go a couple of outings (dumb) and sure enough the bearing on the outside of footbox broke apart, interesting to say the least. To much power in these cars (660 hp) to let anything go, if you look real close you could see black around bearing showing problem which was one problem, but key switch I knew about and when throttle stuck it would have been no big deal to shut off key except it just would spin, had to hold outside of switch and turn key to shut off. Wake up call with no damage is good thing and keeps you on your toes.
