Old 08-05-2015, 08:01 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
After running a MSD system for 15 years (digital 6+ box, billet distributor ) on several Shelbys and HiPo 289 Musamgs I changed back to stock dual point HiPo distributor. No change in idle or performance. The maintence is just checking the timing and dwell once every 10,000 miles. I can live with that. And the look is far better.
Originally Posted by John Martin View Post
When I would go over 110 I would get points bounce . (duel points)
Points did sound-different though
Not all points are created equal. The points that are supposed to go in the dual point distributor have a higher spring tension. It's possible that another brand of points will eliminate the problem.
Z.
'65 K code Mustang
'66 Galaxie 500
