Thread: No start
Old 08-06-2015, 01:06 PM
jhv48 jhv48 is offline
Definitely sounds like heat soak, or a failing starter solenoid.
Is your solenoid separate from the starter? Replaceable?
Granted a new starter/solenoid might fix the problem, but I would try to insulate the unit first. If that doesn't work, replace it.
Back in the seventies, when this happened, we would run a heavier wire from the battery to the solenoid.
Jim
