It's a Classic Glass from Adelaide, same as mine which was built completely by them, this one looks like it has had a make over probably . All their bodies 100mm longer for extra leg room and allowance for seats to mount on rails. to , similarities in dash instrument mainly warning light cluster in front of steering wheel is from either triumph or healy. Engine bay looks same as mine did ,chassis construction same ( from what's seen in engine bay) and classic glass fitted large commodore radiator at an angle with either push or pull fan, position of gear shift and short shift most likely a Supra box which they fitted to manuals behind windsor small blocks, hand brake same, boot lid hinges same.
Don't know about being '01', mines 91/92 model.
Usually Classic Glass mounted a brass VIN plate with manufacture date, chassis No. and name of who it was built for. VIN No. also stamped into top of cross member in front of engine ( that may be it on the firewall).
