Old 08-12-2015, 08:23 AM
decooney's Avatar
decooney decooney is offline
Depending on which version of Butler/Antz car you have It can be a bit of work, cutting of fiberglass, adding metal/bracing in the trunk area behind the seat, adding fiberglass if you want it to blend in. A good metal fabricator can do the metal part and if you not sure a decent glass person can patch it back up underneath. We did my buddies car and it was kind of a pain having to cut away glass underneath to get to a point where areas were exposed enough to get in there and build the bracing, weld it all in. Can be done, just takes time and some patience.
Duane
