  #29 (permalink)
Old 08-13-2015, 07:47 AM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
Brooklyn and Patrick,
I talked to Peter yesterday, 250.00 for the shifter handle. I cant believe the one that you posted from finish line is only 99.00. Could there be be a HUGE difference in this one, and the one that ERA sells for 250.00?
Now I don't know for sure, but I'm willing to bet that the only difference is that the ERA shifter really does feel like the original shifter when you use your two fingers to pull up on the reverse lock-out. It comes up just like the originals, looks just like the originals, wiggles a little bit just like the originals, and you'd almost swear that you were lifting up the shift gate. That's probably the only difference. After all, it's just a dog-legged piece of steel that's threaded on one end and has a two hole boss welded on the other. Ford probably made them for less than two bucks each.
