Old 04-29-2002, 09:33 AM
Whaler Whaler is offline
Assuming its a mechanical gage as it is a Smiths. I would assume its a Nut and ferrule for a 1/8 copper signal line. That goes onto a 1/8 tube to 1/8 pipe NPT pipe fitting. The engine may also be 1/4 pipe NPT so the fitting would need a reducer to go 1/4" to 1/8"
Just have to know the pipe/tube sizes
So i take it you will be replacing the original line with braided?
The gage end should be female 1/8" tube
engine will be the pipe to tube adapter in the same size too
Tim
