  #23 (permalink)
Old 08-18-2015, 06:43 AM
Detroit Bill Detroit Bill is offline
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
Originally Posted by DAVID GAGNARD View Post
Unless you go with a "modern" type engine,you will not have a smooth idling,banshee off idle engine, push rod,carbed, stroker motors just don't do that and make 585hp....
david
I am not sure that is completely true. A stroked 427/482 FE may not idle well but it will pull hard off idle. In a Cobra the tires will be spinning in any event. The HP/TQ is not peaky it is linear. I realize the OP has a Windsor but since he is gathering information that should be pointed out. A 585 HP 427/482 is very different than a 585 hp 351/427.
Good luck!
Bill
