Old 08-19-2015, 08:45 AM
Arvin's Avatar
Arvin Arvin is offline
Cobra Make, Engine: Factory Five MK4
Default Finished my Factory Five MK4
Options:
Vintage Gauges
3-Link
8.8 Rear-End with 3.55 Gears
Standard FFR Disk Brakes – Front & Rear
Dual Chrome Roll Bars
4 into 4 Headers
Stainless Pipes with Heat Shields
Nudge bars and Over-Riders – Front & Rear
Russ Thompson Turn Signal
Ron Francis Wiring Harness
Secondary Fuse Panel
Heated Seats
Cobra Earl Fresh Air Supply
Wipers
Oil Temperature Gauge
Alex Glovebox
Stainless Cup Holders
Cobra Emblem on Trunk, Hood, Steering Wheel, Gear Shift
Replica 427 Gear Shift from Finishline
Cobra Floor Mats from Finishline
Custom Theft Deterrent System (Been Tried but never Broken)
Finishline Door Panels
Rear View Mirror with Slider & Center Rod
Meatballs
Sponsor Decals
Powder Coated Chassis
Wind Wings
Sun Visors
Breeze Angled Steel Frame Seat Tracks
Battery Cut-Off Switch with Bypass
Engine:
351 Windsor, Bored & Stroked to 408 – Keith Craft Racing
Dynoed at 512 hp & 534 ft-lb
AFR 185 Heads
COMP Cams
COMP Pushrods
Melling Oil Pump
Edlebrock Performer Intake
Mahle Pistons & Rings
Eagle ESP Crank
Scat Rods
Moroso Front Sump Oil Pan
Edlebrock Aluminum Water Pump
Ford Racing Hydraulic Roller Lifters
Ford Racing Timing Set
ARP Fasteners
Fel Pro Gaskets
Moroso Plug Wires
MSD Distributor
MSD Coil
MSD 6AL Ignition
Black cobra Valve Covers and Air Cleaner
March Brackets and Pulleys for Flat Belt
Oil Cooler
Breeze Upper and Lower Radiator Tubes
Breeze Radiator Shroud
Relocated Oil Filter
Breeze Battery Tray
FAST EFI
Electric Fuel Pump
Transmission:
Tremec TKO 600
Quicktime Bellhousing
RAM Clutch
RAM Steel Flywheel
Hydraulic Clutch
Wheels/Tires:Halibrand Replica
315/35ZR17 Rear
245/45ZR17 Front
Nitto NT555
Bodywork & Paint:
Jeff Miller
Guardsman Blue & Wimbledon White
Other Work:
Clear Powder Coated Aluminum Panels
Rivets on 2” Centers
FFMetal Firewall Forward
Under Dash Panel with two (2) 12-volt power points, heater vents, seat heater switches, fresh air switches, FAST computer hook-up, I-Pod interface, (2) 1” tweeters, (4) programming buttons for tach/fuel/clock/speedo, volume control of I-Pod
Second Skin Audio Damplifier Pro Noise Reduction – Cockpit and Trunk
Second Skin Audio Damplifier Pro Thermal Insulation – Footbox & Transmission Tunnel
Carpeted Trunk
400 watt Rockford Fosgate Amp
6-1/2” Marine Grade Polk Audio Speakers, 1” Tweeters, External Crossover
False wall in trunk to hide roll bars, seat harness, amplifier
Dual Pusher Cooling Fans
Trunk Prop Rod
Forte Mechanical Fuel Linkage
LED Lights for Cabin and Trunk
FFR MK4, 408 Stroker, TKO600, EFI, Guardsman Blue
