Originally Posted by patrickt
No matter what gauge wire you add to lengthen the existing MSD lines, even if you add wires as fat as your fist, you will still be adding resistance to the line. But fatter wires will add less resistance than skinny wires. The more resistance a line has, the more voltage drop it will have. It's as simple as that.
Regarding mounting the MSD box upside down under the passenger side foot box, so long as you're not driving through a monsoon, I think you'll be alright. I've had it that way for almost a decade... but I've never gotten it wet.
I realize you are adding resistance and fattening up of the wire is the counter, but what about the original skinnier section being a weak link?
Yes, I am not concerned at all about driving in the rain, I am concerned about condensation, especially in the winter when I light off the 180000 BTU salamander heater to work on the car.
Also, you said you have the POS wire going to the CB on the firewall. Same here, but mine is to the top terminal (after the juice goes thru the CB). i think that if we went to the bottom terminal that it would be closer to what MSD had in mind.
That small black ground wire going to the firewall from the engine head is starting to worry me also. I have a bunch of braided straps. What do you think about putting a nice fat one there instead of the black wire?
