Old 08-25-2015, 02:56 PM
joyridin''s Avatar
joyridin' joyridin' is offline
I would use a bigger heim joint with a larger threaded end (maybe 3/4"). Take a 3/4 bolt and screw it in the joint then drill a hole through the center and tap it. This will allow you to have shorter m/c rods and you can adjust either the bolt or the rod.
