Originally Posted by Bernica
A yup there and well worth the peace of mind. You can use a different fly but balance everything before crawling under there and putting it all back in! IMHO.
If you have to buy both a flywheel and a clutch (as I do), then good deals can be had by buying the same brand from the same supplier, so it really is a no-brainer to do it that way. Can then balance them together (with the flywheel imbalance weight removed
Glen
