Originally Posted by CompClassics
Is your car using the two electric pumps in the trunk on the passengers side? If so are the pumps the "Facet" cylinder style? If so there are filters inside the bottom of each pump, if you are running a mechanical pump the filter may be between the pump and the carb.
Mine has the two electric pumps in trunk on passenger side as well as the 2 in-line filters below driver's seat side, then feeding a mechanical pump on the engine that does the daily work with a bypass to run the electrics if needed. I hope that makes sense...
