Originally Posted by Blue66
Ya it does! I also don't understand 2 electric pumps.
There should be a switch on the dash that fires up the electric pumps (you will hear them thumping and slowing down after pressure is built up). I usually run them only on startup routine, then turn them off and let the mech pump do the work. I am told that the electrics are for backup or when you are running low on fuel. I leave them off during regular driving.
I'm sure someone will correct me if I am wrong..
