Old 09-06-2015, 05:41 AM
joyridin''s Avatar
joyridin' joyridin' is offline
My brother has installed a few of the FAST EZ systems in the last few months and they work great. If you think you are going to bolt it on and go, that usually isn't the case though. It will take tweaks to get it running good, but the car will run and you can drive it while you tweak.
As far as comparing it to a carb, that is nuts. There is no comparison. Your car will run smoother, start easier, and be a lot less worrisome in the long run. There may be an area or two across the powerband where the carb runs better, but but across the whole powerband, it won't even be close.
