  #27 (permalink)
Old 09-07-2015, 12:47 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Originally Posted by Eckerz01 View Post
I don't know if this is relevant guys I have rebuilt a lot of top loaders and I do not believe they use a washer under the bolt.I don't think it a big issue except for a small amount pressure loss on the spring.
Some do some don't, most jerico 4 spds seem to use an allen socket head cap screw that is cut/ground to the reqd length. If the trans had a washer and it is not fitted on reassembly it will increase the detent spring load slightly, or worst case if the wrong/longer bolt was fitted it may prevent selection of either 3rd or 4th altogether.
Jac Mac
