Thanks again Treeve
as any pointers would be appreciated as this is my first Cobra build so a bit of a novice.
Although i run my own mechanical repair and fabrication business it still doesn't compare to the experience of some or most of the guys on here that have already done it.
Here is a quick run down of where i am at.
Completely stripped chassis (off to be blasted for a tidy up)
Have been through the complete suspension and rear end and rebuilt or replace anything that needed it (Jag front end, Jag rear end , Jag brakes, MGB steering rack)
Nothing done with engine or gearbox as yet as i am not sure yet as to what I can run. (Any suggestions of what most likely they will allow ?)
Do I need to be in touch with an engineer before i continue with the build ? (Treeve)
Also if anyone has a build manual of a Ram SC that I could buy or get a copy of ,that should help a little.
Thanks in advance for useful comments as I am looking forward to finally becoming a member of the cobra community.
Kind regards Phil
