Last screw of last caliper (inner drivers front) twisted right in half when going to loosen the inner 1/4 bleed screw (housing sheared in half) seeing as i was one man pressure bleeding it made quite the mess...
On searching the inter-web i came across some photos of bleed assemblies broken the same way...
Does anyone have a source for a replacement bleed assy (at least the outside)?
Thanks
SPO 1764 2003, four piston dual bleed calipers x 4
