  #95 (permalink)
Old 09-10-2015, 01:22 PM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
In testing the CB I just went from stud to stud and disconnected no wires. I guess my thinking was I just wanted to see what was running thru the breaker. Maybe that is why the very low reading. Please enlighten me on the Patrick procedure correct way to do this test...LOL
Dave
Naaah, you're wasting your time doing it that way -- and you're only going to fool yourself with the results. Measuring resistance will only get you so far. For example, let's say you have two wires, one is a nice new fat 0 gauge battery cable and the other is a ratty old piece of copper strand the thickness of a dog hair. You get out your trusty multimeter and you check the resistance on both wires and they both show just about no resistance. Maybe the dog hair is actually a little less in ohms, who knows. What does the test tell you? Nothing. The moment you put a load on the dog hair the wire will go *poof* and you'll have an open circuit. In order to really measure a "thing" that is on an automotive circuit, be it a span of wire, a circuit breaker, a fuse, a connection, etc., you must perform a "voltage drop test." That's your next lesson after you master clamping your inductive amp meter around a wire.
