Old 09-10-2015, 08:50 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Someone recently found the anti-rattle clips installed on the wrong side of the brake pad. Caused clicking sound.
Agreed Jaydee, check caliper mounting bolts.
Also the top shock mount.
Pins are tight on the wheel adapted..... wheel is tight....
If you coast to a stop, do you still hear the noise or only when braking?
Both pads are making contact with disk when braking?
Blas
SPFWiringDiagrams@Comcast.net
