  #99 (permalink)
Old 09-12-2015, 12:12 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Ohm function is great for finding opens in the circuits. A bad relay, faulty heating elements like in your stove are all easy with the OHM function.
It is very good for finding a poor connection in electrical connectors.
If you measure resistance across many electrical items and compare a known good one with a questionable part, you can usually find the problem.
I frequently use the feature when chasing electrical problems in the house or garage.
A typical quality DVM can handle 20A in series. That is enough to check most automotive circuits. Look at your fuses; most are 10A and 20A. The starter is more than 20A draw.
A good quality Fluke or other DVM is a must have if you work on cars.
John
