Old 09-14-2015, 07:44 PM
tortuga tortuga is offline
Default Mechanical Oil Pressure Gauge Replaced with electric
Bought the gauge and sender from Niosinger, ($250 ish)
And a ford sender extension from Summit-needed to fit sender: http://www.summitracing.com/parts/sdk-c2oz-9b339-c ($25)
and a 1/8-1/4 reducer bushing from the hardware store to adapt the sender to the extension. ($1.79)
It was a breeze to pull the sender wire through, just jammed it in the hose and pulled the hose through to the guage through the existing sleeve.
The light has the switched 12v dash power and a system ground, the only other wire was switched 12v that i pulled from the green bundles on the wiring tray 9beside the signal wire).
No more oily weeping oil sender or the possibility of an oil leak into the cockpit.
Superformance 1764
Built 427W
Aiken SC USA
