Old 09-17-2015, 03:00 PM
joyridin''s Avatar
joyridin' joyridin' is offline
I disagree on the TBI set-up. Obviously they do not work as well as port fuel, but if you just want to bolt on a system that mimics a carb in looks, it is a good deal. It will start every time, no sticking floats or puking gas up through the vents, no running massively rich on one side, and no vapor lock on a hot day with cheap gas. Besides the fuel line, which you can hide if you are really good, it looks like a carb especially if you have an air cleaner that sits low.
If I wanted the original or nostalgic look, I would not hesitate to buy one over a carb.
