Old 09-20-2015, 05:41 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Wow 79 views with no comments. I have been talking with Rick Lake. So here is the scoop, the bellhousing and block plate were previously aligned and doweled. However, the location of the bellhousing and block plate are far enough towards the passenger side of the car resulting in pushing the starter away from the flywheel. I am not sure of the cause. Could it be the wrong bell housing? Bellhousing bolts? Poor alignment of the bellhousing? Here is another pic of the problem. All the starters I have tested have the same result. Any thoughts on the best solution?
Phil
