Make sure your fan belt is tight. Friend had the same problem, jumped thru a lot of hoops until he checked to make sure the belt was tight. 2 minutes later with a pry bar and wrench, the problem was solved. They do stretch a little over time and the slightest loosening can cause a non charge problem. first step....is the unit plugged in?
We make 3 bad decisions a day. Choose them wisely.
