Stephen
I've a G-Force that essentially morphed out of the RMC as the two RMC partners separated back in the day. The G-Force runs a full steel tunnel and this I assume was the means to get this kit around the twin rails need for bend testing.
The kit would certainly be a good solid starting point and if you can get it sub 10 gorillas I think you aren't doing too badly.
Worth some research on the bend testing needs, cause as Lobelly says, if you then need to do some cutting and shutting on the chassis, this is time and expense.
Might somewhat also depend on how handy you are with a wrench and welder, as to whether this is an option for you.
Have fun researching.
Steve
slowy
