Dcapo...
Uhhh,
We make the custom columns for CR's. All new bearings, etc.
Elimination of the "muffler" pipe extension, full tilt, and not only is it a direct bolt in, the harness will plug right in!
If you want we can also supply the proper Flaming River shaft extension and both U-joints, which eliminate all slop and play!
If you don't like it, then we simply refund 100% plus shipping!
Trust me on this one...
You will love it!
We even make one with the key on the column or we shave the column so you can put a key on the dash.
If you want one, just add it to your fax tomorrow!
Ohh, and these are totally collapsible in case of collision!
DV -- 300 Cobras are (or is it "is" ?) NOT enough! Have you registered yet?
