Old 09-30-2015, 05:44 PM
Grey 65's Avatar
Grey 65 Grey 65 is offline
Cobra Make, Engine: BDR #888, Keith Craft 408
Originally Posted by ASO544 View Post
Thanks... I may change my gears to a 3.64 or 3.73 from 3.46 while its out. Are our gears 168mm or 188mm? Also im guessing the rebuild kit are the seals and bearings?
188mm.... I had 3.46 in my open diff and have 3.46 in my 60% locked diff. What gear you use/need depends on the engine and trans you have. If I went to a 3.73 I wouldn't need first gear... With a 3.64 it would have been debatable if I would have used first gear.
Yes, since you have it all apart best to be safe and replace everything.
The oil you want to use is Amsoil 75w-140 severe gear oil. 3
http://bimmerdiffs.myshopify.com/col...products/188mm
Kevin
Kevin
