I have a stonger bracket to support the rear end along with solid bushings up top. The axles are better and hardend. The tranny is the tremec tko road race version, D&D has not seen one break, yet. Hardend and better axles, may have been worn out along with a shock mount . I think I may have it coverd.The one issue I think is a design flaw is the hub. The inner and outer bearings are inside of the wheel 6 pin mounting. I think the outside bearing should be outside of the flat spot where the back of the rim mounts. The set up on cobra country is my set up. I guess that the jag's are the same way. Mine is a 9 inch center also. The biilit hub broke in half which is beyond me other than the design flaw. The car started hunting on acceleration/deceleration so I knew right away. Thamks for the help. scott
