Old 10-02-2015, 10:30 AM
Wisconsin_Snake Wisconsin_Snake is offline
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Default I need to ID the steering harness wires for start and run
(I am wiring up a Fuel Injection wiring harness and it needs the 12 volt constant (while ignition is on) and the starter wire.)
I need to ID the steering harness wires for start and run. Here is the wiring harness schematic that I have.
I am pretty sure that #126 is for the starter.
Which is is constant run (even when the starter is being cranked)?
I thought it was #125 but the voltmeter tells me that when I turn the key to engage the start it goes to 0 volts.
Thanks
Close up so that you don't strain your eyes.
