					Originally Posted by Armrer  Thanks for posting the pix Larry! Jack will be finished by Wednesday, I'll send final pix then.    |
 OK, I know it's Friday.. but been a long week! I found this stainless 1 1/8" hose diameter spring clamp at McMaster-Carr  (part # 5324K93) that easily modifies into a jack retaining clip. A Dremel with a cutoff wheel is all you need to trim the ends off. Wire diameter is 1/8", so it fits the shaft groove with just the right amount of tension. That wraps up a proper rebuild, and this jack works silky smooth!
Larry will post pics later, along with the (almost) final asembly pics.
