10-06-2015, 05:14 PM
TX
Cobra Make, Engine: ERA #812 427/482 FE
Originally Posted by Paul F
While you may be set on a 2 post lift, the Bend Pak full height scissor lift provides full access and height while not having two posts in your way when not used.
I have the SP-7X. A further advantage, since you are building new, is to build the scissor lift in flush with the floor. The drawback being that it lowers the effective lifting height. BendPak SP-7X Scissor Lift, 7,000 Lb. Capacity, Frame Engaging
Thanks. I had not considered this lift type, but I will check it out. It would be nice to not have the posts in the way.
Chris
