Originally Posted by eunosracr
Thank you Cbreeze. I will check them out today. Question, do you actually put in 10 qrts when filling her up?
Yes. A good way to check your pan capacity is to fill to the bottom of the windage tray (keep track of how many quarts) as this still clears the crank. Don't forget that you will have
oil in the engine and filter which lowers that level when running. Never had any blow-by problems, even at high RPM.
