So, I took a starter plate to a machine shop and they mis machined the starter plate. I will not likely be able to convince them they did so I will likely kiss that $500 goodbye. I am going to re-align bellhousing with dowels and loctite Once that is done i will drill out startr mount and grind down the block plate to make this work. I am so sick of this problem and not knowing the cause. Not sure what else to do...
Phil
