Sorry I am sooo late in finding this thread. I assembled the engine in question. It was "dry" on the dyno, but FEs rarely seem to stay dry for long.
The comment on dye is spot on - - I have seen leaks from all over the place get diagnosed as rear seal because that is where it ends up dripping from. Liquids will do an amazing job of following along edges in the castings and gaskets to find the way to the rear. I usually find tiny leaks at the junction of the intake and the cylinder head to be the hardest to trace down.
The Shelby block used should be OK - its not that old and should not have the rear drainback issue - that was from a very long time ago. If I recall correctly it has the complete Aviaid pan and screen kit. I use the TF-31 gray Motorcraft silicone on assembly on all pan & tray surfaces. Still possible for stuff to go wrong there - but the pan gasket is usually OK.
On aluminum blocks it seems that every fastener needs a turn or two after some run time & then they are OK for a long time. The pan gaskets are especially bad since they are sandwiches of gasket, tray, gasket and you cannot really tighten them much with damaging & distorting things.
Check the
oil level - and get the dye kit. Fix it when its cold and wet - - enjoy the car and the weather while you can. It was 34 degrees F here in Detroit right now...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
