Old 10-20-2015, 08:18 PM
deano59 deano59 is offline
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
Originally Posted by stiffy View Post
Hey Auswallaby,
I always use 4 straps, I can load my car onto the trailer in about 5 minutes.
I have set the trailer up to hold the two front wheels in place similar to the
Porsche set up and I cross the rear from the lower suspension points.
I always check after a while as the straps sometimes come adrift.
I have modified the straps so there is no long tail hanging off that will flap in
The wind. I find it extremely worrying that some guys towing a beautiful car will
Not spend the money on the correct straps or for that matter trailer. It is
Piece of mind for me to have the car thoroughly tied to the trailer. I enjoy towing
Now as I have had a bit of practice and the car is not going to move.
I also keep a spare wheel bearing kit, nuts, longer tie down straps, cable ties,
D shackles, tools and a 6 pack of Cider just in case .
Why is it not recommended to hook the winch onto the car?
Stiffy
if the winch should short circuit for any reason and start pulling the results could end in tears .
ive had this happen on one of my tow trucks i had the cable hooked onto the back of the tray and somehow water got into the controls the next morning i went out to find the hook had straightened under the tension till it let go and smaked into the back of the cab tearing it open granted it prob was a bigger winch than most would use on a trailer but the damage could still happen
cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
